TwinTurbo.NET: Nissan 300ZX forum - ok, i've the wd-40 trick, adjusted the idle correctly w/
Subject ok, i've the wd-40 trick, adjusted the idle correctly w/
Posted by inf on July 19, 2008 at 7:19 PM
  This message has been viewed 88 times.
In Reply To Do these two things: posted by BobbyT on July 18, 2008 at 03:57 AM
Message a computer as well as cleaned all the connectors i could find w/ electrical cleaner. It's still doing this weird idling. I also tested the resistance on the aac and the injectors, did the hose clamp test on the air regulator, checked voltage on the tps and adjusted timing to 15 degrees. I get code 55, tested the compression. Would drilling a hole in the aiv hose to relieve the water in it cause this problem?
